Unable to start after distributor removal
(In Topic #217637)
The distributor shaft had a lot of up/down play, maybe 5mm. Is this normal? No side to side play though.
Last edit: by goldie_88
Early 77 year model Golf. 4-Door
Last edit: by Steve1973
Use the has mark stamped on the side frame of the diz housing.
Manually set it to 0tdc. Then Spin the intermediate shaft to rotate the diz to 0 time as the center of the rotor is at the middle of the hash.
If you re-time your engine to 0, at the crank finger is the dimple on the back of the cam at the plane of the engine head or even with the valve cover tin, and the rotor is in the middle of the hash. The rotor is then at number one Cylinder, to the rest of the wires are in order 1342
Anyway, now I’m not quite sure about the wiring for the powerspark. Red powerspark wire goes to coil live with 12V , but I have a resistor wire along with live to the coil which gave around 8v ign on. Will I fry the coil if I bin this? Another thing, the instructions says no other wires should be connected to the negative side of the coil apart from the powerspark/dist, but there’s another red/black wire (upper) also attached to coil which I am not sure leads to. Anyone know the proper way to set it up?
p { margin-bottom: 0.1in; line-height: 120%; }
Never mind just seen your post LoL, glad you got it sorted.
Well worth binning the points and condenser in favor for those electric ignition system. I used a Accuspark in my 1978 Mk1 Scirocco.
I don't know how I could of been doing it wrong for all those years
I ran points etc for many years with out any problems as long as you have dwell meter and check the gap every 6 months they are ok, the problem comes at higher revs as points can bounce when opening and closing fast and you don't get a clean spark.
Well worth the £30 ish for a electronic ignition kit, I've had my Accuspark for about 3 years and they are still going strong.
