Trolley jacks
(In Topic #241043)
They do me well, although I had one once that leaked and was problematic, their customer service is infuriatingly bad.
With a Floor Jack (trolley?), you Jack one side, Jack stand it, then
Repeat for the other side. I have a low Profile Double Piston that has a extension of 22 inches. Double piston is that you get higher faster. If I need more clearance I have 6 2X10's buy 12" that I have so I can get some additional height if needed, and Occasionally I need more height. I also have 2 sets of 4X4X12, Two are screwed Together, then I have a 2X8X12 that I can screw to them I think I have had mine about 3 feet in the air once. But I was very safe about it.
Now I have had occasion where I had to use a bottle jack under my ride to raise things when I was too lazy to get out my engine lift.
When I do get my car lifted, and jack standed I leave the trolley under it on a pinch weld for just touching the steel as a safety. I used to have a set of Ramps, but with my newer rides, getting them up on the ramps involved Jacking the car up and putting the ramps under the tires. Big P.I.T.A..
