torque settings with a triple layer head gasket
(In Topic #211411)
many thanks ian.
I would use the recommended settings for the 2.0l engine the 1.8l is 60Nm +1/2 (180 degrees) turn, and they have to be NEW bolts, as Old Bolts have been stretched and will not hold correct tension.
60Nm is 43ft/lbs still with +1/2 (180 degrees) turn.
You can do this is 1/4 increments that is 90/bolt.
Go with the recommended torque values for the 2.0L then after 500km re-check for the correct values.
