Timing marks
(In Topic #220923)
cheers Steve.
1.8 carburettor EX engine code
Last edit: by Steve1973
Each dot is 2 degrees BTDC.
Only ever seen the newer style of flex plate that the marking are more plain.
Of course there were 2 styles of Starters for each version of the flex plate and they aren't interchangeable.
Putting the wrong starter on the wrong flex plate will cause the Teeth to Strip I know that personally as my daughter had one installed without telling me… Trying to source the correct one is a JY feature, and looking for hens teeth. As a Get thee by, I welded up the teeth, and Grinded and Filed them back and that lasted about 2 years with the correct starter, until I found a flex plate.
Here is a side by side on the Spoked in the rear and a Solid off a 88 Cabriolet 2h/010
Flex
solid
Solid starter.
Spoked starter has lugs on the casting in the circled areas.
I had to replace it when the my cavity repair finally gave up.
I usually time my Green one (solid) at the 3rd dot, where I see that the spoked plate has a 1|8 stamped at the far left so you could be correct.
