Timing belt tensioner pulley stud
(In Topic #212019)
Need spec or, shop that sells new.
I have a new timing belt and tensioner kit but, it is the Febi one that doesn't come with the stud. Stud screws into engine block and then has a non-threaded part where the timing tensioner pulley sits, then threaded again to screw the tensioner tight.
What is the spec / where can I purchase this stud on its own. I don't wanna use my old one as it looks a little gnawed up, I also don't wanna purchase a whole new kit just for the stud.
Thanks!
Gillie
00111337 m10.
It isn't unusual for them to get bent and not be a true 90 from the block as they usually get bent on a engine mount drop…
Wierd, as over here when I get a Tensioner Kit, it usually comes with the Tensioner, stud nut and washer….
Beck/Arnley was the last one I bought that came complete.
Thanks for the help! Anyone who has found a parts shop that sells the stud's separately feel free to chime in!
cheers again.
nut is N 0111337 at 95p+VAT, and you also need a washer N 0122314 27p+VAT
Which I should of mentioned in my previous post.
my 2p would be pop into scrappy and nick one out of another mk2 or mk3
Looking forward to getting the job finished. Thanks for your help!
Cheers👍🏻
