View topic: Thermostat housing – The Mk1 Golf Owners Club
Thermostat housing
Replaced my thermostat on my 1.8 gti cabby and now it won't close up properly so water leaks out slightly.  On the housing (plastic) should there be a rubber o ring or as this come from there old thermostat as its this rubber ring that seems to stop it closing up tight however closes up fine with o ring without any thermostat
Hi,
I'm sure it's not this, but I assume your new thermostat came with o-ring already supplied??
1990 - Cabriolet GTI 1.8 (DX)
Thermostat housing
Yes new one had one and one came out with old one but there's another one attached to the housing???
Again, ruling out the obvious here.
When I replaced a previous housing (on front of block) the previous gasket had become so perished it has almost forged itself into the plastic housing, I had to scrape it out which then allowed the two parts to seal nicely.
NB: It was nigh on impossible to notice the gasket had forged itself into the gap, I only spotted it by chance.
Thoughts?
Thermostat housing
Oh right that might be it then as there's no gasket which I thought was odd so it may have done the same and sort of gone ring shaped. I was fairly stuck would move. So might be worth scraping it off
if your thermostat housing is plastic bin it and buy a new one. it'll probably be too warped to seal properly
All plastic thermostat housing should be banded
Buy a metal one youll only have to do it once :)
Thermostat housing
Done some ex searching but where can you get the metal ones from
early mk1 golfs, so not easy to find unfortunatly
