That super charger noise. !!!
(In Topic #212918)
I've had the car since Xmas and it had a whine when I got it so checked both timing belt ( which was changed in the service before I got it along with tensioner ) and fan belt. Both seemed at the correct tension so presumed timing belt needed to bed in a bit.
A few weeks past and decided to renew the alternator bearings to eliminate that.
Just fitted new water pump and still sounds supercharged., Have removed fan belt and ran the engine so no water pump or alternator running so that leaves me with can, tensioner, intermediate pulley, or crank. Thinking maybe the tensioner but its hard to tell as the noise seems to come from lower down.
Do these noises ever come from the end of the three shafts?
Is it worth changing the tensioner again?
Any suggestions welcome.
1990 Golf GTI cabrio 1.8i. DX Engine
Thanks.
I've definitely ran out of ideas now.
What are the transmission covers and pp that I need to check? Sorry to ask.
Thanks.
I think I'll just buy a new timing belt kit and fan belt so I can eliminate them.
Fingers crossed..
Well a new set of belts, tensioner, and as Briano says new stud are on order so will let you know.
Cheers.
Sorry that I can't help you with a specific solution gooner and I know it was an expensive way to cure it but it was worth every penny.
Thanks for all the advice as always people.
Marc.
