Stumped Bleeding Brakes
(In Topic #207153)
Now I'm stumped. Here's the situation:
LHD 1988 Cabriolet
9" Front Rotors
180mm Rear Drums
Car has proportioning valves(are they really needed?)
2 man method:
Front Right and Rear Left bleed properly
Front Left and Rear Right have nothing coming out.
pop the reservoir off and look down the affected circuit hole make sure fluid can get inside from the reservoir, take the line off and blow down them too
I'm going to stop by autozone to borrow a pressure bleeder to see if that helps. If not it's time to dig.
Maybe a reverse bleed or a vacuum bleed off the nipple would help too.
Blade3562 said
Finally got around to installing my new brakes. New master cylinder, entirely new rear drums (Shoes, springs, retainers, wheel cylinders and drums themselves.), new pads, rotors and hoses up front. Kept all the original hard lines as they were clear 1 month ago when I bled the system.
LHD 1988 Cabriolet
9" Front Rotors
180mm Rear Drums
2 man method:
Are Proportional Valves needed? YES. they prevent the rear brakes from locking up by reducing the pressure to the rears.
At one time, VW on some Cabriolets and Golfs used a load sensing proportional valve located @ rear axle to increase or decrease the brakes on the rear. Very pricy for repair of it.
As stated the Master is a cross diagonal unit, left front right rear and right front, and left rear. So if you can bleed one side, then I would say that the master is wonky. I have had new off the shelf units fail, and or reman units fail out of the box, bench bled and all.
You can make your own power bleeder for a few quid, there are plenty of how to's on the interweb.
I used the 2 people method for years, Trained the wife and kiddies on how to do it.
I have used a home made power bleeder for about 8 years know, and I won't go back, prior to that I used the speedy bleeder valves, which are spring loaded to stay closed. You loosen them for about 1/2 turn, place hose over port, and press the pedal about 3 times, then close the port.. Worked really great.
I have also used a Mity-VAC tool, it has but one flaw, as I don't think it as a flaw but more as a OBTW…
It will pull air in from the threads of the bleeder port, so you have to remove them and wrap the port in Teflon tape (yellow gas tape works best). Be sure to poke a hole in the port after taping. This is also a great tip to insure that your bleeder ports don't rust in the caliper or cylinders, and I have been doing that for years.
I also strongly state to create a bleeder catch jar out of an old Glass Pasta jar. Drill two holes in the top. Place about 3 foot of vinyl tune in one side about one inch from the bottom, and then a piece about one inch inside the top about 2 foot long. Seal the vinyl hose with either RTV or JB-Weld (Epoxy). You can bleed safely into the jar, or use it with your Mity-Vac to Pull new fluid through the entire system.
speedy bleeders:
Collection jar:
top
top and bottom:
Home Made Power Bleeder:
We've invested probably 15 hours into this now and it's just so frustrating. Bleeding brakes should be so simple not this challenging lol.
I'll give it one last attempt tomorrow, but even a vacuum bleeder couldn't pull fluid through. What is The thread pitch on the brake fittings so I can buy proper plugs to try a better bench bleed on the master
Very frustrated at the moment. I'm not throwing in the towel just waving the white flag lol. Was hoping to make it to a show with it on Sunday but seems highly unlikely.
If so, check the vacuum line into it.
