Strut Brace
(In Topic #223243)
Strut Brace
https://www.ebay.co.uk/itm/GENUINE-VW-GOLF-MK1-CABRIO-SPORTLINE-RIVAGE-FRONT-LOWER-BOTTOM-STRUT-BRACE-K-BAR/133022388140?hash=item1ef8c08fac:g:i0kAAOSwBDVcszbN
Not cheap. People say they are good. I can't comment as I have always had one.
Does a '91 Cabi not come with a K-bar?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
It does not fit my 1978 Mk1 Scirocco as there is a bracket which holds the exhaust manifold downpipe in place as the Scirocco has the older style 6 bolt exhaust manifold.
https://www.ebay.co.uk/itm/MA-1535-OMP-FRONT-LOWER-RED-STRUT-BRACE-VW-GOLF-MK1-GTi-ALL/191991884333?epid=8017025102&hash=item2cb39baa2d:g:gskAAOSwXEdahxI5
Mines a manual gearbox, standard 020 Gearbox.Greenmk1 said
Hi mark1gls, sorry for getting back so late but is yours a 5 speed manual or is it an auto? As I dont want to send it back do to it not fitting. Also is there a way to finding out which gearbox i have got in my golf.
Post up a picture of your gearbox, top pic, bottom pic and if you can see the flat area near the starter motor there should be a code stamped onto the gearbox.
or have a look here, does it look like this?
scroll down the page and the yellow square in the picture show you where the gearbox code is.
http://www.brokevw.com/020oil.html
Last edit: by mark1gls
Its tight but doesn't foul anything.
On a cabby the upper braces will have no effect at all due to the 2 RSJ's between the rear struts and under the dash, will be looks only
Current rides:
Greenmk1 said
Forgot to mention as there are 2 types for the front bottom strut brace, 1 with a bend in it and the other is a straight one.
Straight Brace.
Curved.
Strut Brace
Sent from my SM-G930F using Tapatalk
Strut Brace
I did notice you are missing the plug to cover the timing marks on the fly wheel, it's on top of the gearbox.
https://www.ebay.co.uk/itm/VW-MK1-MK2-Golf-Genuine-Gearbox-Inspection-Plug-Cap-020301129-BRAND-NEW/271144195259?hash=item3f217414bb:g:~lUAAOxyDEVSdsn~
Or here.
https://www.classic-vw.co.uk/020-gearbox-timing-plug-020301129d-4032-p.asp
https://www.classic-vw.co.uk/020-gearbox-timing-plug-cover-020301132-4034-p.asp
Shop around as lots about.
The OMP strut brace will fit or the K-bar one mentioned in a previous post.
I fitted mine yesterday
https://www.heritagepartscentre.com/uk/WHT001937-gearbox-sealing-plug.html
Showing out or stock at VW heritage but a search of the part number showed this place but check it's right..
https://www.brickwerks.co.uk/gearbox-oil-filler-plug.html
I brought mine from a VW dealer but I expect they still might be closed?
https://www.classic-vw.co.uk/mk1-golf-lower-strut-brace-k-bar-style-black-11885-p.asp
Although I did ask the question when I bought it and you use the old bolts.
Hope that helps?
