Struggling to start when warm
(In Topic #216216)
Mk1 GTI starting issue
I'm having an issue starting my mk1 when it's warmed up. The car starts well when cold but I need to pump the accelerator a fair bit to start it from warm. If I forget to pump the accelerator when it's warm it can be a nightmare to get going again and can cause backfires with flames shooting out of the exhaust. I changed the fuel filter last year which had no effect. Wondering if it might be the fuel pressure regulator?
The car runs really well other than this starting issue.
Any pearls of wisdom greatfully received!
Black 1984 MK1 Golf GTI Campaign.
Fuel Injection usually doesn't require pedal movement at all on start warm or cold, where as some Carbed Cars require 3 stomps of the pedal prior to start to set the choke. Had a Dodge, and a GMC that needed this every time…More so when cold than warm.
ie: Digifant uses a CTS sensor in conjunction with a Fuel pressure Regulator. On start warm or cold, the ignition key should be turned on for 5 seconds at run prior to turning the key switch to Start.
CIS has a fuel pump check valve that can cause the fuel pressure to bleed off when warm. and a WUR that can give greif as well.
Over the years on Carbed cars I have owned, I have had
fuel run back to the tank sucking the carb bowl dry, automatic chokes fail….Vapor lock on fuel lines that heated up as the engine sat and boiled the fuel as the lines weren't being cooled by running fuel….
Diesels, that had a fuel return and feed line leak that caused hard starts as more air than fuel was in the Injection pump.
So as I stated more information is needed.
So it's a 1.6 or 1.8 Petrol injection.
Roach said
He says it's a gti.
Guessing and knowing for sure are two different things, as over the years of life, things may have been swapped about a bit. Years matter as well as year difference between Digi/CIS… and yall do it way different than over here on this side of the pond.
Over on this side, I have seen CIS gutted for Carbs, as well as Digi gutted for Carbs.. Diesel engines installed on gassers and Gas engines installed in Diesels.
I never assume anything, as I have been proven wrong a time or two on Previously Stock Cars.
Briano1234 said
Roach said
He says it's a gti.
its safe to assume if someone in the uk refers to a gti it is a CIS, also we did not get digifant mk1,s or have air con
Lasts few Gti cabriolets, 91/92 may have digifant injection system as well as a CAT fitted….
As Briano1234 says, a little more info like year of car, engine code etc is always a good idea, if you edit your signature you can put all the important info so it's always there and you don't have to re type it… See below in my signature.
sporttrucker said
well I have never seen a UK spec digifant cabby, or find one now, plenty of 91/92 k jet cars about but no digifants. we didnt have to fit cats in the uk till 1993 so didnt need the digifant to get lower emissions, we had cats fitted to JH engined cars with jetronic ecu on some but its still a cis with added emission control
mark1gls said
You could be right as I'm usually wrong ……. I thought the last few UK cars 92/93 had digifant injection, cat and some even had power steering as VW was throwing on allsorts of stuff to get rid of it?
Gee all that stuff was standard equip on the 90ish cabbies over here, and early 90-91.5 we even have digi1 in california as well.
But as I said, given the age of these little guys, and the upgraded interiors and engines/trannys I have seen happen over the years by well meaning previous Owners " Ya just never know what you are working on or looking at."
They do start better from warm on super unleaded aswell, if you're using standard try letting it get low then use that.
have you removed the screw at the rear to see if petrol pours out?
New accumulator are expensive for what they are.
GSF- use discount code to get it cheaper…
https://www.ebay.co.uk/itm/VW-Golf-155-17-Mk2-1976-1991-Bosch-Fuel-Pressure-Accumulator/302537023712?hash=item46709ca0e0:g:GzIAAOSwh1paEzMa
I think someone on here fitted one of these, slightly smaller but I think it worked?
https://www.ebay.co.uk/itm/0438170015-BOSCH-FUEL-ACCUMULATOR-K-JETRONIC-BRAND-NEW-GENUINE-PART/183034551073?epid=1009506624&hash=item2a9db59b21:g:5EsAAOSww85aaHPl
cedar said
I think your problem is more likely to be caused by too much fuel rather than too little so probably not a faulty accumulator. You could try cranking it when warm, stopping before it starts then having a look at the plugs to see if they're wet.
The problem of over fueling is the car is being started by pumping the accelerator, (see 1st post) you should not need to touch the accelerator when starting a fuel injection car.
But yes flames, back firing is to much fuel in the engine.
Wrong type of fuel, timing out, old spark plugs, Ht leads, Dissy cap and rotor could also not be helping starting…..?
I did wonder if overfuelling might be an issue, it seemed similar to me to trying to start a carbed engine when warm with the choke wide open. To expand a little, I don't touch the accelerator pedal at all when starting from cold and it starts right up. When the car is warm, if I try to start it withought touching the throttle at best it'll just about start and stutter for a while then go but usually if the accelerator pedal isn't ridden a little when starting from warm it'll just keep turning until the battery goes flat. Plugs were changed about 800 miles ago, not sure about distributor or HT leads. I haven't tried running it on super unleaded but will give this a go too.mark1gls said
anyway moving on, its an 83 GTI. warm start issue could be down to loss of residual pressure. the usual cause is non-return valve in the fuel pump, which is handy becasue its reasonably cheap and easy to change. the accumulator could be leaking inside, if you can undo the small slot drive screw in the end and fuel comes out, you need to replace it, and these can be pricey!
