Storage
(In Topic #240843)
I’ve got a very drafty garage which it’s keptin, which means it gets quite dusty. I’ve been told using a car cover can create moisture, which will encourage it to rust (further).
Also, do I take the battery out and trifle charge it? Or starting it up every now and again? All tips welcome!
Thanks guys
If you have a trickle charger, use that. No real need to remove the battery to do that.
Over inflating the tyres is one I have heard as it can reduce flat spot tyre deformation, but I reckon it would need to be sat quite a while for that to be an issue. Saying that, I do that with our MGB as it never goes out in winter.
I'd also leave your windows open a bit to stop any damp build up in side the car.
Oh, and fill the tank, this prevents excessive moisture build up in the tank that can cause rust.
Sure others will have more to suggest.
Storage
Stabil in the fuel tank, with a couple of cans of De-icer works well, wouldn't even hurt to have a Octane booster as well When storing I also add about 6 to 7 ounces of
SeaFoam engine treatment in it as well.
