Steering wheel boss help needed!!
(In Topic #215578)
Hi looking for advise on finding the right steering boss to fit my late cabriolet? Also can one be found without removing any part of current spline after reading afew posts.
specific year would be nice.
Shouldn't be too much of a problem finding a 'big spline' boss for later MK1's but you'll first need to decide which brand of steering wheel you're going to fit.
The number of bolts and their patterns vary from brand to brand and although some are interchangeable most aren't.
It's a 93 and looking to fit a Momo steering wheel.
Think later ones are 26mm??
You can pull that spline off too if you need too.
Didn't want to go down the route of pulling it off I've seen to many bad stories! Can I just buy a boss which is a stright fit, where are you getting that 26mm size is it the length of the spline.
Diameter… that was a guess from the depths tho.
Later mk2 we're the same size. Think the spline size changed in the late 80's?
An expert will be along shortly I'm sure.
I got my momo boss kit from vw heritage
Ok cheers, so the large spline boss is a stright fit with no messing about.
Also has that Momo boss got a part number?
Was on mine just lined it up I put a very small amount of copper slip on it and slid it on ( tight fit even with the grease which is good)
Its easier to pick up a larger splined boss than a smaller one.
Any Mk2 golf boss will fit
Current rides:
Ok cheers.
