Starting issue
(In Topic #204347)
engine turns but won't fire up, have had a few backfires through the carb so don't think it's far off.all timing are lined up and have fiddled with distributor to try and get it started but nothing
any other ideas what would be preventing it from starting?
Set the Engine to 0tdc on the transmission by moving the Crank
Set the Cam to 0tdc by moving the dimple on the back edge of the cam to the top of the valve cover tin, not the re-bar the base tin.
Set the Distributor so that the rotor is in the middle of the hash mark on the side frame of the dizzy.
Do not try to use the intermediate shaft pulleys. It is far easier to make sure that the dizzy is at 0time to the crank and cam.
I think your base time or static time is a wee bit off.
www.cabby-info.com has pictures of the timing marks and how they should be set.
Top tip for changing a cambelt: slice the old cambelt in half widthways while its on the engine, ie slice it so a 20mm belt gets cut to 2x 10mm belts while still on the pulleys. Then remove half the old belt, slide the new belt half onto the pulleys, then cut the remainder of the old belt off and push the new one fully on. Then you never need to worry about timing marks!
So check the marks again and make sure you are using the right marks on the cogs as the cam shaft has marks on both sides and some cars you go by the mark on the inside and other the marks on the outside.
The valves in cylinder 1 needs to be closed.
