Stalling help
(In Topic #221249)
If I slam the brakes on sharp it just cuts out and a flick of the key and I’m back up and running, I suppose this could be a million and one things but you never know someone may have had and solved this problem before
Any help would be great
Stalling help
Therefore I'd check the hoses and elbow from the servo to the engine and also make sure the hose is clear as it could get blocked by crud from the engine.
Next, if you can't find anything, check the breather on the rocker cover and the crankcase ventilation system.
It could also be that the engine idle is too slow, but if it's okay normally, I don't think it will be that.
Braking hard and using the pressure in the servo is similar to taking the oil filler cap off with the engine running. The engine idle drops by a couple of hundred rpm.
The other times I've had something similar is when the engine is worn and the crankshaft pressure is increased.
Hope this helps.
Post back when you find it, always helps others in the future.
Sent from my Moto G (5) Plus using Tapatalk
If you want the PSD Boot Sticker file, it's here: Boot Sticker
Stalling help
Isn't there a one way valve on the hose? I'd check that as one of the first suspects.
Stalling help
