Speedo
(In Topic #244080)
Erratic Speedo reading
My question is can I change just the Speedo into my existing cluster? Will a Mk 2 Speedo fit ( seem cheaper) ? Are there any internal parts that I could change to save my Speedo ?
Many thanks
if you have a VDO then look for a VDO.
As you didn't mention that or the year, for oem stay with the oem clock set. mix and matching a clock set may involve moving the wires around a bit on the harness.
It isn't that hard just have to be careful.
I personally have had issues with bouncing dials, since my clocks have never been apart, I tried the speedo cable first. They can wear out and the inner sheath can deteriorate and can make the cable catch.
Im sure i had a problem with the needle bouncing when my battery connections weren't tight.
Only take to bits if you are not using the car for a while, or get a spare binnacle
