Seat belts
(In Topic #219266)
You need to spray in onto the seat belt material and polish it off…. The Pledge/furniture polish makes the seat belt slippy so it retracts easier.
It worked on my seat belts and my wifes VW Touran.
Seat belts
You leave the metal bits where they bolt to the floor and on to the pillar, but you can take the pillar part off. If you throw a couple of pillows in the dryer that reduces the noise.
Replacing Slow Seat Belts in Cabriolet | Volkswagen Owners Club Forum
Seat belts
Seat belts
unless it is upright it don't like to disengage.
If you at the very end of the pull of the belt, it can cause the gravity dog to be bound, and not re-spool, so you have to take the cover off and manually disengage the pawl from the lock.
Seat belts
Seat belts
You can use my how to as to taking it apart and trying to re-tension the spring to retract, but it is easier to go to a breakers and get the rear seat belts out of a Jetta, Cabrio, or Passant, and use them to replace your current
one, you may have to change out the Gravity dog,
I took a set out of a Cabrio (rear seat belts) and used them to replace my worn out ones on my Cabriolet.
There are companies out there that will repair your Belts. Google them and you will see… usually around 50 bucks each USD over here.
rubjonny said
and if you do decide to split them, take extra care as they like to explode everywhere
That my friend is an understatement and it is Humpty Dumpty…. Just cant get it back together again.
This is from some one who knows.
Seat belts
I watched a video once of then installing the clock spring on a similar thing and it was all mechanical no hands were used but to position it in the jig.
It is like a "Slinky" and about 150 yards long as you are trying to wind it back up (ok, 10 to 12feet) and it is like climbing Mt Everest with no oxygen.
Looks easy on a map, doing it is a tad more difficult…
The edges cut your fingers like a knife, so wear gloves and that makes it more difficult, besides it is greasy grimey and slips out of your control in a millisecond so also wear safety glasses.
Seat belts
short while later *bang, ping, ping ping* from behind me. turn round to see sheepish look on mates face
