Running poorly please help
(In Topic #204640)
So I tried revving it as I did so the revs went down to nearly stalling and gradually picked up but when I let off the throttle it kept making like a poping noise
Any ideas guys I am clueless
On the drive
Myvalver 89 GTi Grey mk2 16v
It was just strange that it stopped working Overnight
Are the injectors prone to breaking down do you know
What is the thing connected to the fuel pump under the car I have been told it is a fuel accumulor is this correct and could this cause the fault
How old are the HT leads, dissy cap and rotor arm? If you are not sure it's worth changing them as well as part of a major service.
There is 2 fuel pumps on theses cars, 1 in the fuel tank (lift pump) and 1 underneath the car (main pump) the accumulator only holds the fuel pressure once the car is switched off so it's easier to start when when hot as the fuel pressure is already there, it won't make any difference to tick over or running.
If you lift the base of the back seat up you will see a black cover, remove this and you will see the top of the fuel tank, start the car and then unplug the connector if the main pump gets noiser and the car struggle to tick over/rev the lift pump is working if not difference your lift pump may be dead. New lift pumps are £25 new.
The old one was full of grit prob from the tank
