Reversing light switch issue.
(In Topic #216022)
I've taken the plastic black top hat off and it looks like when you engage reverse the steel inner pipe spins round and (now I'm guessing) would push a bar to generate at short across the plug and lights on?
Mine doesn't have a rod in it so can't see it would ever work?
Last edit: by Pete M
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Mk1 and 2s should have MFA type or
Like I said earlier something must cause a short across the plug and the only way I can see that happening would be a rod through the housing that would contact the plug as the the lug on the tube moves round.
Edit, just found this image and I can see a silver something that if pushed towards the plug would short it?
the plug bit pops off, on the back it has like a rubber dimple which is what the pin pushes against. if your lights dont work either the pin is missing or theres a fault with the switch piece. or maybe the cup is missing off the tower
