Reverse light
(In Topic #210288)
How to test switch
1990 Golf GTI cabrio 1.8i. DX Engine
Manual
Shift it in R, then use the test light or DVOM between the
Pins 0 ohms resistance, or a light lighting with the test light
Automatic…..
There is a Shorting bar as the mech sweeps, it shorts out the pins on the R position.
Also on the Automatic that has the Brush Dust guards, the bristles can brake and as you move the Mechanism it can cause it not to make connection. Usually in Park or Neutral you can't start your car…..
manual www.brokevw.com has all the different Back up switches shown.
This only works if you have this type of reversing switch.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-MK2-1-6-1-8-GTI-REVERSE-LIGHT-SWITCH-BACK-UP-LIGHT-C674-/200824519873
If you have the early type switch you will have to find another way.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-GTI-CABRIOLET-MK2-GTI-REVERSE-LIGHT-SWITCH-C281-/221587550763
Thanks guys.
Reverse light
