Removing glass - How?
(In Topic #208563)
Any suggestions as how to remove the glass without cutting off the seals?
ta
Ian
I'm not taking any responsibility if your screen breaks using this method, a new seal is a cheaper option to a new windscreen….
For the sake of £23 quid I would just cut the seal:
http://www.ebay.co.uk/itm/262735927520
cut the inner lip that the screen sits inside from the outside, you can cut a groove in it without going all the way thru then just peel the lip away. keep at it till you can just lift out the glass, then remove the remainder of the seal from the frame
Go inside the car and ease the rubber seal away from the body and slide a bit of metal between the rubber and the glass. Start at one corner and go along the top and then down both sides, keep a couple close to the top corners. When you've gone all the way round or run out of bits of metal, ease the rubber out of a corner and very gently push.
At this point you will hear a tinkling sound which will be either the metal strips falling out as the screen comes free or (if you've pushed too hard) the screen falling onto the floor and smashing into a millions pieces !
since they made the mk1 chassis for as late as if not later than the mk2 you should still be able to find screens for them
Thanks for the tip
I went through my insurance but I used a local company recommended to me who deal with classic cars and found out he also has a Mk1 Golf, they have delt with all the paper work and I paid my insurance excess.
I called National Windscreens for a quote if I paid them direct and not used my insurance they wanted £265!! so I would not use them…
