Refitting Water Pump O ring
(In Topic #224429)
On refilling the system there is a leak from behind the pump, so I am guessing the o ring is not properly in place.
i have read that you shouldn’t use sealants or instant gasket and the like, so how do you keep the o ring in place as you place the pump against the engine?
Any tips for dealing with those hose clamps would also be appreciated.
Thanks.
when done you will be happier not to revisit for few years.
On the drive
Myvalver 89 GTi Grey mk2 16v
Having taken the pump off, reseated it on a new o ring and bolted it down, I refilled before putting the alternator back on.
It was leaking again, it took 15 minutes of close inspection, drying the block, and trying to look from all angles to realise one of the hoses was emitting a very fine spray out the back where you can't see.
Fortunately it was so near the end I could move the clamp and solve the problem.
Thanks for all the replies. I am sure the wisdom gained will help someone else too.
On the drive
