rear shock absorbers replaced, car now too low
(In Topic #243564)
Mk 1 Rivage - body of car hitting tyres with passengers in the rear - never been a problem before
the springs seem very springy - not sure how else to say it. I have checked with Bilsten and they say the parts are correct. Any ideas what to do next apart from re-fit with new parts?
I have had the car for 23 years, always carried passengers,/loads - beginning to wish I had left it alone!
Sounds as though the new springs are incorrect in some way, so compare with the original ones you took off.
Either that or the shocks are for a lowered car and the bump stops aren't doing their job properly
Last edit: by golfy1
I just wondered what make/model others use for their Cabriolet springs if they don't want to lower them
Passenger car
Last edit: by typ_53b
You must somehow have got the wrong springs?
In what way are they different, different length different number of coils, different wire diameter?
This is obviously the source of your problem. The make of spring is irrelevant, what is important is you have the wrong ones fitted.
