rear anti roll bar...why is it there?
(In Topic #240734)
I'm baffled can't see it being any use
I think you've answered your own question to be fair. I'm sure the boffins at VW knew what they were doing, and why.
I have just finished refurbing mine with new bushes and a reconditioned anti roll bar from crazyquiffs. My god, it's a heavy piece of kit😀
(typically) To make a front wheel drive car turn in better you need to stiffen the rear, or inversly loosen the front. Depending on your driving skill, leave the rear anit roll bar alone and disconnect the front. The car will turn in better.
I don't run any sway bars at all, started out as a CL model so none were installed. I have 36 way adjustable coilovers with custom spring rates, stiffer spring rates in the rear.
The rear beam also pivots on the factory rubber bushings this causes the outside tire to toe out helping the car to turn in, also causing the legendary inside tire lifting off the ground. Installing poly bushings in the rear beam stops this from functioning and causes the car to push in corners.
I run poly everywhere else, even the steering rack. The car rides very nice turns well, very neutral.
If you get your setup wrong it can cause the rear to come around on you in hard cornering, so if you're not well versed on the subject I'd recommend sticking to the factory setup, or an aftermarket kit.
See my videos, Tom AFH
