Rattleing Seats!
(In Topic #207692)
How do I sort it?
To refit, push the cover on and push the pins back into there holes till they are flat.
Black thing on the left is what is being mentioned, and this one was broken.rubjonny said
tilt the seat forwqard and it'll be obvious even on 5 door they have them, you just have to release the 2 big latches at the bottom corners by hand
part number is 171881299C, heritage have em if you needed:
https://www.vwheritage.com/search/?act=search.searchResults&sType=quick&maxDisplayRows=15&searchText=171881299C&btnSearch=
apart from that look at the clamps themselves that go round the bushes to make sure both sides fully lock in position and hold firm, pop the plastic covers off as mentioned earlier to see fi there is anything obvious up with the backrest angle adjust mechanism
Also you may want to clean the pivot where the clip is, I use a thin coat of grease on it. I have found that over the years, that I have to replace the slides and front catch about every 6-7 years, and I have rebuilt the seats from the cushions up.
I know that they will squeak some, but don't usually rattle.
If the seats rock side to side then the bushings are shot.
The one bushing has a finger on the outside to prevent the side to side movement, and if the bushings are out of place then the seat could rattle on the slide I suspect.
The fingered Bush goes to the outside rail.
Also if you get the slides on wrong (I HAVE SEEN IT) they become hard to scoot.
I also place a thin coat of grease on the upper and lower rail cups.
Here is a how to that I did for my seat rocks and is hard to slide.
Cabriolet/Rabbit Seat rocks, and hard to slide | Volkswagen Owners Club Forum
There is also a big difference between a Cabriolet bushing set and a Golf.
Briano1234 said
IF your seats fold over, check that your seat latches are fully engaged, some times they will rust bind and not fully seat to the bushing.
Thanks so much for this. I will check!
