Problems with idle and hot starting
(In Topic #209897)
I'm guessing this may be fuel related.
Any ideas chaps?
We need much more detail then that please. 👍
Golf Cabrio said
Can you please tell us what engine you have and is it injection or carb. If carb what are you running?
As well as the engine type of fuel system
Carbed, CIS, (which CIS -e-k) or Digifant.
Then Automatic or manual.
1.8GTI is a Plethora of things.
Not sure what you mean by CIS or Digifant, sorry
However, the root cause of these issues could be the overall condition of your fuel system. If you haven't already checked inside your fuel tank for debris this is the first thing I would do, otherwise you could end up going round in circles (been there, done that!)
Quick check on the accumulator is to check if there is any fuel leaking from the small screw on the end (if so it needs replacing)
Malcs_cc said
Manual gearbox, fuel injection
CIS e-K have metal Jacketed Fuel Lines to the back of head SS wire braid over Rubber hoses.
Digifant there is a Plastic Fuel Rail holding Electrical (usually blue) injectors.
Digi
Vacuum leaks, you need to replace all cloth covered hoses and check the idle bypass Screw on the back of the throttle body. You need to clean the ISV and Validate that you have good grounds from Battery to frame and frame to engine/tranny.
CIS hates vacuum leaks as well and it to has the throttle body Idle bypass screw that can be a vacuum leak.
VW's hate leaky vacuums.
I've posted pictures towards the bottom of this thread.
View topic: Looking for a Mk1 1.6gti engine - The Mk1 Golf Owners Club
for the idle going up and down I expect your car is ticking over on the idle stability valve (ISV) if the revs get to low it kicks in and increases the idle speed it's meant to work when you turn on the headlights, heater, rear heated window etc when there is extra strain on the engine to stop it stalling. Try increasing the idle speed there is a screw at the back of the throttle body which can work it self lose or the rubber O ring is past its best. Adjusting the idle screw will not upset any thing so it's worth a try, after you adjust the screw blip the throttle a couple of times to settle the engine, idle speed should be about 950-1000 rpm but I find mine happier at 1000rpm.
Ive posted pictures in at her thread about the idle screw and the print here.
View topic: 1800 DX idle low (Update Now Sorted) - The Mk1 Golf Owners Club
Last edit: by mark1gls
As before check inside tank for rubbish. Via back seat pump cover. Give everything a tap with small hammer when warm or add some wd40.. may free up some sticky parts.
On the drive
Myvalver 89 GTi Grey mk2 16v
It does not matter so much when the car is cold as extra petrol is sprayed in by the 5th injector to help start the car.
I had nightmare with my old 8 valve non start when hot changed everything. In end put down bein f::ked ( broken ) Spanners came out 2,0 abf fitted now
