Poor Start Up and Emissions
(In Topic #207417)
I looked back at the certificates, and the Golf failed with 7% CO but they turned it down to just 0.97%, when it only needs to be lower than 4.5%? is it safe to turn the mixture up myself and leave it until the next MOT? i can't measure the emissions myself so i would be judging on how well the car is running rather than what a probe is reading out the back end.
'85 MK1 Golf Cabriolet GTI
Website Manager
lhasadreams said
Hi mate,
Which engine is it ?
1985 1.8 GTI
Website Manager
What fuel are you using? adjusting the idle speed and timing may help.
Mixture is the last thing you should touch, timing and idle speed then mixture if all the ignition side of things are in good nic.
1 - 1.5% is fine so yours is about right now.
lhasadreams said
You would not want it higher than 1.5%
Okay, thanks guys, i guess ill leave the mixture alone for nowmark1gls said
Clogged air filter will increase emissions, how does your look?
I use any fuels tbh, mostly the unleaded from Tesco.
The idle is around 1000rpm already.
Yeah i feel it has been a lot worse since. She always took a minute to warm up, but would fire up after 3-4 revolutions.Deandubya said
was the starting issue fine before the MOT or only after? spluttering etc…
It seems a little noisy, to the point to where i can hear a whirring sound from the back of the car when i'm sitting in it at idle. And that is over the slightly 'ticky' engine and above average exhaust note.
When i've been cranking it to start, the fuel pump is still whirring when the engine splutters and dies. Is this normal for the fuel pump or is it not providing enough pressure the prime the system or something?
I'm not very mechanically minded nor do i know the ins and outs of a Golf
I could not get my car run smoothly on normal unleaded and was lacking a little bit of poke and lumpy tick over, I've switched back to super unleaded.
mark1gls said
Gti run best on super unleaded, worth changing over to super and you may need to advance the timing a little if someone before has retarded it to run on normal unleaded. If they did not retard the timing your timing is out so could affect running.
Thanks a lot, i definitely try switching the fuel over before trying anything else
