Please help!!!
(In Topic #215154)
Carb base flange
Has anybody got one of these I've bought the wrong one 🙈🙈🙈 Manchester area!! The one I have just taken off is the bigger one and I've bought the smaller one 😩😩.
What car have you got?
They seem to list the same one you have. Has someone changed the engine or inlet manifold as Mk2 or possibly mk3 golf flanges look similar to yours??
Sorry can be much more help as I'm not up on small block engines.
something like this but I could be wrong????
http://www.veedubmachine.co.uk/volkswagen/golf/golf-mk2/mk2-83-92-fuel-emissions/carburetor-flange-for-1-0-polo-golf-mk2-derby.html
I'm not sure
mark1gls
I'm not really mechanically minded 🙈🙈 I will get one from somewhere! Cheers for the help tho 👍🏻
That doesn't look like a stndard MK1 smallblock to me. I haven't owned a smallblock Golf for over 25 years but the 1.1 and 1.3 looked the same and that looks like neither. If it's a lump from a newer model then you need to get a carb flange for type of the car it came off.
Can you find the engine number to see what car it could have come from?
Looks like a polo engine.
Yes that's the one I need @Raul thanks!!
That carb flange is for a 1.0 engine, you may find you have a 1.0 not a 1.3 engine so your insurance may be cheaper?
Best find a engine number to double check because if it is a different engine it's best to change log book and tell your insurance as if they are not told theses things they can void your insurance.
What carb do you have fitted? That might help tell you what engine is fitted.
Just guessing here, is the engine number below the dizzy on a small block?
I think it's a 2G?
http://vag-codes.info/files/engines/vw-engines.pdf
1.3 fitted from 1988 to 92 so Mk2 golf
Yes that's a Webber carb, you can just see the W on the side?
