Petrol grade
(In Topic #246298)
Got it booked in for an mot next week as it’s been garaged for a few years.
You can also meter it in to your vacuum system, but use a small diameter line and a valve, as you will be fogging your neighborhood.. If you let it suck in too much it will cause the engine to sputter and stop, good for the injectors and valves.
When I would do that I would use a air hose from an aquarium and a set of pin valves to regulate it.
I picked up a few gallons of E5 and all seems to be running well so fingers crossed 🤞 for the mot on Friday.
Next job is the window scraper seals (I've saved your how to guide) but I'll do that after the mot test.
