Perfect idle until throttling
(In Topic #237227)
Odd one this.
Car starts fine, I usually give it a bit of throttle (habit) but the idle is rather low and lumpy, thought this might be due to the mild cam. Sounds like it is about to stall, but it never does, I'd say its about 700 rpm. When it is warm it idles fine.
I noticed today when I started it (cold) without touching the throttle, it sat perfectly at 1000 rpm, never moved. Then when I blipped the throttle, the idle dropped down to about 700. Tried it again later in the day, same thing.
Car drives fine and like I said idles great when warm.
Any ideas what the cause could be?
Thanks,
J
Oh, I forgot to mention my car is cammed too, running TT 276, think it's 114° and 110° or something. Not as lumpy as I had hoped but sounds…..ok.
Last edit: by Shubbs
Mine started mucking about, and I found all the hoses had perished the last 5mm or so. It's only a little leak, but lots of little leaks add up.
Might be worth letting it tick over and spraying something like wd40 at each connection / gasket area (including the inlet manifold to head). One thing at a time. If the idle changes, then you've found your leak.
What I did do is pulled out my carb balancing tool. Carb tune, and found my carbs were all way out of sync. I managed to re-sync three out of the 4 barrels but cylinder 2 just won't come down for some reason. Looks like I have way more vacuum on that cylinder the other three. Not sure why. Also while I was doing this I messed around with the idle mixtures screws on my carbs. Engine sounded better after all the tweeking but still don't know why cylinder 2 won't tune up like the rest.
Anyway, long story short, after I did that tweeking the car runs better now and doesn't die after I throttle it. So i seem to have fixed one problem but found another…….
