Paint and code
(In Topic #221434)
The only solution I can come up with is the order was changed very late. The chassis plate, body chassis number and boot sticker all tie in with each other.
On the drive
Myvalver 89 GTi Grey mk2 16v
On the drive
The car is registered in March 1983. I couldn't find the A45 or XC code either.
Last edit: by Vic
https://clubgti.com/forums/index.php?threads/vag-option-codes-decoder-list.283422/
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=bodywork-fittings-and_2%2Foption-codes-that-can_2
https://www.uniquecarsandparts.com.au/colour_swatch_volkswagen_1983
http://www.elferclassic.de/technik/farben/plack-gruen.php porsche greens…wow
well yes thats annoying…. even the options is a bit vague as normally have more than that…,even down to gear knob, number lights,steering wheel type
On the drive
Some nice colours available , and with all colour coding its irrelevent as due to sun and weather you will need to match aged paint work if touch up, here in uk normally they give you a swab of paint code with 5 different mixes to try match better.
On the drive
