Oil Pressure Warning Light & Buzzer Help
(In Topic #242505)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/berries.png)
![Stockster in the usergroup ‘Paid Member’ Stockster in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Stockster in the usergroup ‘Newbie’ Stockster in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Hi all help required -
Just got the car (1989 1.8 Carb) out of storage had a service & clean MOT, however on the way home have a oil pressure flashing light & buzzer. The car is running great & temp OK, when I checked the oil level it looks like it has been over filled is this the possible cause if not any suggestions ?
Cheers in advance for your help
That is the Low oil pressure at RPM warning.
It is the large White Sender on the Oil Filter flange.
Make sure it is plugged in and that it didn't get knocked off at the MOT.
I would replace the sender, then test it again Light and Buzzer then I would get a set of Mechanical gauges and test it.
Possibilities:
Bad oil pump that is in by-pass mode.
Bad Oil filter if generic.
Bad Sender.
What weight is the oil that is in there?
Possibilities:
Bad Sender.
Hi Briano - many thanks for the response I have checked and if I am looking in the right place it looks like it is missing now as I can see the spade (in picture) where does it connect to ?
Thanks for your help
![Oil Filter.jpg Oil Filter.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1714918054/uploads/attachments/663792a64af05.jpg)
Hi located it and seems to have been disconnected for some reason, seems to have fixed the warning light & buzzer - so thanks for your help.
