Noisy gearbox
(In Topic #242379)
When the clutch is depressed it goes quiet so defo gearbox whine.
Could it be the release bearing ? I've replaced it but may have got it wrong ??🤷🏼♂️ that would be the easy solution to replace….
If not think I'll have get a recon unit and get it fitted.
It's certainly fought me every step this Golf
4 or 5 speed?
Make of Trannny Tj AUG
TJ was my Automatic.
Have you changed the Gear LUBE. If you have a 5speed the 5th gear is splash driven, so if the fluid level is low, you can burn out the 5th gear.
It's also leaking gearbox fluid out of speedo cable location" despite new gasket and fixing bolt being tight ? 🤷🏼♂️
