No Spark
(In Topic #245176)
It has electronic ignition (which worked), a new coil pack, spark plugs, leads, dizzy cap and arm and ignition switch but there's no spark.
What am I missing?! It worked one day and not the other.
TIA
Mk1 Golf 1.5 GL
Does you car have the hall sender on the side of the distributor (if it's electronic, it should have). Would be worth testing that - it is basically what triggers the LT side of the coil to deliver the HT to the dizzy cap.
Worth getting hold of a Haynes or Bentley manual for proper test procedures, but this might help:
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Fhall-sensor-where-can
