No power when key in ignition
(In Topic #220615)
No power when turn key
The rear car is on axles stands, just putting new brake cables,shoes & cylinders on after failing mot on the rear brakes.
I went to put the interior light on and plug a torch in the cig lighter.
Nothing worked when i put the key in the ignition. No Immobilsor flashing no ign lights on dash lit up nothing at all.
It was all working sat when i put it away in the garage on sat am.
Paul
Battery cable come off?
Check your fuses in the fuse panel, then look at a red accessory wire off the main power cable if it can pull the wires and they stretch really really easily, then you have found your bad fusible link or links. Disconnect the Ground prior to cutting out the old. The little wires not the one to the starter usually.
Yes you can spice a new section of fusible wire in to it, or replace the wire with new wire and a couple of fusible links.
Should any lights come on when ignition is turned to on?
My handbrake light lights up that's it.
Should my fuel gauge go up?
Sent from my Pixel 8 using Tapatalk
