Newbie help caddy 1.6d won't start
(In Topic #221013)
Hold with pliers
Short the nut of the plug to the battery negative, and the screw tip to the positive, if it doesn't get red hot in 7 to 15 seconds it is bad, and you need to replace all of them…
A diesel will start on one bad GP, no GP's no start.
Verify that you don't have air in the fuel (clear Line).
Verify that you have 12V to the stop solenoid at the rear of the Injection pump.
then also check the firewall fuse is still good first and that you have 12v to frame with key on both sides.. then test the GP;s after turning the car off.
