mk1 sportline
(In Topic #208651)
fuel tank colour
hitty said
is the fuel tank black from factory or silver
Umm I think they were silver but I'll use my 'Telephone Joker' and ask my mate and Sportline guru Shughy
mark1gls said
What ever colour you like as no one will ever see.
Oh I just knew that was coming!
Shughy said
I believe it was silver but could be wrong. When I replaced mine it was a silver one and I Shultz it to protect it a bit from road dirt etc
Well I'd bet my Wife that they were sliver but as Hugh said you might want to give it some kind of projective coating, like the rest of the underside.
What I tell folks is to do a couple of things first.
Clean the exterior with 100 proof alcohol, then place some self sticking roofing material on at the top, and a couple of strips on the bottom. Cover all the outlets and sender hole, then spray with a self etching primer. Follow that with a coat of color if you choose but better is the body Shotz or hardening under coat, and a coat of color over that once it hardens.
The self sticking roofing material is avail in 6 inch wide strips and when stuck to the tank before pain or after sound deadens it……
hitty said
I'm building 1 now to concourse or as best as I can and that's why I'm asking
OK so you want it Concourse not bomb 💣 proof! 😂
Although the process above is a very good one! 👍
Compulsive buyer of knackered VWs!!!
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
'93 Mk1 Sportline LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
Briano1234 said
Over here they are "silver?" well actually Metal as in unpainted, and unprimed. Or for 5 dollars more you can get the black primed.
Briano1234 What a waste of perfectly good alcohol
Good tip there mucker, I've got a new one on the way so will be following your advice.
Is Wild Turkey an acceptable alcohol to use? Or can I just use some panel wipe?
Panel wipe is good too.
Wild Turkey and the like are better applied in your tank and not the cars….. (well they are trying to get the e-15 and 20 fuel over here)…….
