Mk1 GTi fuel hose routing under car
(In Topic #223864)
Can anyone post a pic of the correct layout and routing of all the fuel hose pipework under the car on a Mk1 tintop GTi.I have full stainless hoses installed from CrazyQuiff's for main supply and return lines, fuel tank to pump, fuel pump to accumulator and accumulator to supply line. The fuel pump is installed on a new stainless bracket (again from CQ's) on the rubber bobbin mounts, as well as being inside the original foam pump holder.
Everything just seems to be a bit tight for space around the pump, and the return connection onto the tank (short length of standard rubber fuel injection hose) is very restricted for space as it comes out right above the fuel pump foam.If anyone can get me some detailed pics of the correct original layout that would be a great help.
My new CQ fuel line from pump to accumulator has failed quite significantly due to a manufacturing defect on the crimp so while this needs replaced (good job I spotted it on the drive, 5 bar fuel leak through a reasonable sized split = a significant volume of fuel spray), I want to re-do the routing of all the hoses.Many thanksPeter
Last edit: by Pistol
Regional Host NE
nicci21paul said
you sorted with the pipe work mate
Not yet bud. Working at the minute so can't get near car, but have just ordered the replacement hose from CQ until I can return the burst one to him for refund. I really want to cut this failed hose and examine the failure point as I'm concerned about it for the rest of them now.
Regional Host NE
I've just done mine - see pics
Mine were a VW set so you would think they'd just drop into place - but no !
The clip in bottom left is a red herring on the GTi - that's what I've found anyway (See last pic). I also replaced the lock clips on the bulkhead with some self tapping home made straps as the originals were quite weak to hold the springy fuel lines. Pic 3 shows the existing clip which I replaced. The fuel lines then go onto the clip on the N/S chassis leg.😏
I've got these too, do these show what you want ?
I've not put my fuel pump on yet as waiting the brake pipe set from Crazyquiffs - the brake pipes route behind the pump so pointless fitting it all up
Let me know if you need any more closeups my Golf is on her side so easy to take pics of stuff
They are a bit confusing. I had no idea how they went, but I've got a few pics off restoration threads - I took screen shots of things I found might be useful.
Fitting the engine bay was a nightmare for me 😩
