Mk1 golf GTi 1983
(In Topic #243806)
Headlights
My theory is to remove the lense from my original headlights and replace them with the new headlight lenses. Has anyone ever done this is it easy? Just kinda wanna know what i need to do and is it possible thanks
Any other ideas are also welcome
The bulb holder will be set to give the dipped beam "kick-up" to the right, rather than to the left. So swapping the lenses over will not resolve your problem. As well as the lens and bulb holder, the reflector might also be asymmetric, optimised for driving on the right. I think your best bet is to get in touch with your supplier and see whether they are able to swap them for the correct lamps for driving on the left. The lamps they have supplied are not suitable for use in the UK and they should know that.
Some parts providers don't have a brick and motar store but are Internet based and ship from others OEM'sS supply chain.
Basically they are usually part, country, and car ignorant, and are just reading the pick sheet.
Ordering the correct part comes in to play and the onus is on the User behind the keyboard.
I too have been Suckered by ill worded confusing descriptions.
Cutting the lenses off of one for the other will not be a good thing to do as it will probably be worse off.
