mk1 golf front engine mounting welded in front panel
(In Topic #241529)
i need a photo of the bracket welded into the front panel
I have found that the internal bracket that the front engine mounting bolts onto has rotted away and I am going to cut the inner panel of the front pressing away to get at it and make a replacement. The trouble is I am not sure what it looks like. If anyone has a picture of this bracket, which is sandwiched between the two parts of the lower front panel it would be a great help. This part is unavailable and only comes mounted into the complete lower front panel.
Thanks, but that isn't the part. That is a discrete part that fits at the back of the bit I am trying to find the pattern for. The bit I am looking for is sandwiched between the two leaves of the front bottom panel.
wish I had better pics.
I think it's just a thicker piece of steel sandwiched between the two panels, or at least that's what I have welded into the space occupied by the missing rusty metal. Thanks for the pictures
