MK1 gearbox help
(In Topic #209152)
I checked the cable and it was fraying so i though it was stretching and swapped that out but no luck, still grinding.
I had a look around and people were saying to change the oil, did this and now it seems to start to grind when it gets warm. (i have filled put 2 liters of 80w90 Gear oil in, I think Mr Haynes says to put in 2.2 so i'm going to get some more and test tomorrow)
Anyone able to share some knowledge on this?
Edit: the clutch cable is adjusted all the way to the top, its a manual adjust cable on a 1.3
As you state it is full up, so you either have a clutch issue, or a possible cracked actuation finger …..
When you go to change the clutch, I would suggest that you do the finger as well.
Welcome to BrokeVW.com
As for oil changes on my 1.8 car with a 020 gearbox I can never get the full amount of oil recommended back in, the last gearbox I changed the oil for was off the car so I could even hold it up on a angle to drain all the old oil out and I could still only get in 1 and 3/4 liters of oil in to get it to MAX mark and the books says it takes 2 liters.
Many be worth checking the bulk head where the clutch cables goes through as these are prone to cracking as it's a very weak point, you can get a strengthening plate to stop this happening or repair a bulk head with, if you don't have a plate fitted FIT ONE NOW, they are £16 ish and saves a lot of work/welding if the cable pulls through.
They can be stuck on if the bulkhead is not damaged and cleaned.
They are also available on ebay and other places.
https://www.vwheritage.com/shop/171898152/bulkhead-repair-patch-for-clutch-cable-mk1-golf-jetta-sciro/
