MK1 Clipper fuse plate relay and fuse layout
(In Topic #243469)
All the relays and fuses out of the plate - which goes where?
Hi all. I'm resurrecting my 1991 clipper (Australian delivery) that has sat in my mother's garage for 17 years.
For silly reasons the fuse panel was stripped years ago but I don't know which relay goes where.
I've looked at https://www.cabby-info.com/files/electrical/Relays.pdf and can identify the relays by number … but which piece goes where in the jigsaw? I'm reluctant to just find a match and leave it to luck.
(I've omitted the load reduction relay - it's unmarked but obvious where it goes)
The car is 1.8 K-Jetronic with lambda. It also has after market AC and lecky windows (the dealers fitted them as a pre–delivery option so they might not be genuine VW parts … or perhaps are but not matched to the build data).
Cheers.
Cheers.
So much to swear at, so little time ...
look at www.cabby-info.com.
Be warned that the floating relays at the top of the main
fuse panel could be anything and that you will need to check the wiring and plugs on the rear to verify the positioning.
A bentley is going to be needed in your future.
from
https://www.cabby-info.com/images/electrical/90-93FusePanel.png
from
