Mk1 1982 1.6 GTI not starting
(In Topic #209468)
Regards Volkswarren
Regards Volkswarren
Probably the light circuit, very common unfortunately, the bulb on the heater panel gets knocked out when removing the dash, or the cig lighter one, so drops on earth and can fry a lot of wires as well as the dash pcbBAZ-GTI said
Had a look at my speedo which I removed and one copper strip seems to look like it's been burnt don't know it that's might mean something been shorted ?Â
Sent from my iPad using Tapatalk
Regards Volkswarren
Regards Volkswarren
Wiring gets knicked, brittle, corroded, connectors get loose, connectors get broken.
Earths on the Autos VW, had a unshielded stranded ground (EARTH) lead that ran under the Battery to the Frame.
This wire is subject to Corrosion, Road moisture spray that includes Corrosion producing salt and the like.
This Corrosion can get between the strand and grow because of Electrolysis. As it is coating the bare individual wires, it starts to insulate then, and lowering the current capacity of the Earthing wire to the car.
It can also start to cause intergrainular corrosion of the base metals, as there is the natural issue of differential metal corrosion Steel to Copper, copper to lead…electrolysis added increases the deterioration of the connection.
Avid and Raving advocate for proper grounds.
I have seen grounds that go bad. The friendly and devious electron can use anything it can that is lower resistive to get to POWER.
Things I have personally seen are Fried Clutch Cables, Fried Instrument clusters and lights because the "Speedo Cable" was used in the Starting Circuit and had melted the Speedo in to a mass of plastic and bits.
Sensors that are mounted to the engine, and provide a Ground path to the Cluster, and ECU.
Electrons are Devious, and Devoid of guilt if they have to fry things to get to the Power, they don't care what they ruin….to get there. Spurious grounds are easily controlled….. through Proper Grounding.
DVOM's can test for continuity, but they can be fooled in to thinking it is good, when under load it isn't. In the Old Timey days we checked for valid ground in Buildings, cables, and airframes with a device called a Meggar. It produced a High Voltage Pulse (Hand Cranked) to send a smaller version of a Lightning Bolt down the cable to test for grounds, and we would find Marginal issues quickly.
Vw in their wisdom, used connectors on lamps and switches that were Bare, as the clearance of the connector to the switch or Lamp was tight and that a insulator was too big.
A lot of Lamps, and Switches, have these bare things attached, one that comes readably to mind is the 4-way hazard switch.
Heat Shrink Tubing cut to fit and shrink around these go a long long way to insure less shocking results.
They also didn't fuse the Interior Lighting Circuits Directly in earlier mk1's that they did in the latter ones.
A direct path to ground on the gray/blue wire can wreck havoc. A burning wire can burn or melt the insulation off of anything it touches.
To correct it you have to Isolate the wires that were "touched" and splice in a new one or insulate them again with Heat Shrink, or Tape.
When I have had that issue on my rides I usually use Vinyl Electrical tape UL certified, and over wrap it with "Friction" tape as that is more likely not to come unglued over the years, I find it usually gets Stickier….and can be a pain in the posterior to remove. Vinyl Electrical tape can get Brittle, and come untaped because of Chemicals that you might spray around them.
Removing all connectors and cleaning them when you are around them only can make them more better. I occasionally will remake them, or tighten them with a pair of pliers.
Ok, enough of the bad ground rant.
Trying to find where the issue occurs is looking for the most burned area. Usually a Switch, or where ever there is a Frame member that has knicked a wire.
All the lamps run in Parallel to the switch and if it was the last lamp that shorted can cause the whole run to get toasty.
A lamp that Flickers, can be a flaky connection, or a precursor to systemic issues.
Lamp Filaments that break the right way when hot, can re-acquire connectivity and work when turned on, then open up again and go off. They can drop and Short out the light, and start the whole world burning.
On the VW's over here, I have seen 2 distinct types of heater Facia panels, One with a integrated bulb, and one on early Scirocco's with a separate bulb holder.
On my Cabby I have the Integrated one, and have had to replace the BULB with a LED.
I know I haven't assisted you in the repair, I have just recited a few of the things I have seen. You are going to have to investigate, and repair.
A DVOM, and the wiring Diagrams are going to be your friend. On Older Cars you have to get dirty.
I got my Education on 50's and 60's British Leyland cars
I learned all about Lord Lucas, Prince of Darkness, Well if Lucas was the Prince, then Bosch was his second cousin.
Edit….. just found this..
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2F1800-gti-wont-start
Last edit: by mark1gls
