Mk 1 drive shaft seals and bearings
(In Topic #218342)
Hi,
Am having the drive shaft bearings and oil seals replaced on my Mk1 GTi.
The firm that is doing the job will replace other oil seals as routine.
I will replace clutch.
Is there anything else that it would make sense to do while the gearbox is out?
Installing a new power steering rack if it is out is easier.
Installing a 4-2 dual down pipe and manifold is easier.
Working or replacing the Steering rack bushings is easier (well one side)…
Replacing the Battery to frame and frame to engine/tranny ground wire will keep the electrical gremlins away.
