MFA LCD Replacement - new screen not working
(In Topic #228849)
I'm just about to tackle this tricky job, and don't want to have to do it again if the screen ends up being upside down.
Last edit: by Pistol
Next problem got it all stripped down, new LCD installed, all back together but the clocks are still dead. The lights all work with ignition on, just the LCD blank. Checked fuse 3 but it's fine.
Is there an easy way to put 12v on the clocks somehow to see if the LCD is working? I wasn't able to test the LCD before I installed it.
Any ideas if this is a dud display or something else?
I've tried disconnecting battery, removing fuse etc. If I assume the display is actually ok, what can I do next? Maybe I should leave it all connected for a while and see if it starts to show the time.
There’s differences between the GTI and Clipper as they’re non MFA.
chortle said
Depends on which LCD you got in the first place
It's definitely an MFA screen, it's got the 6 arrows along top and bottom of screen for each MFA function.
