Mechanical fuel pump needed
(In Topic #214428)
Mk1 golf 1.3
In need of a mechanical fuel pump for 1.3
I also need the rubber base the carb sits on mine has split
Any help would be much appreciated 👍🏻👍🏻
https://www.vwheritage.com/052127025b-fuel-pump-mechanical-mk1-2-golf-jetta-1986-small-engines
Don't know what carb you have so can't advise on the base?
Thanks Raul and I will take a pic tonight and add them I'm not sure either not really mechanicals minded 🙈🙈😂
That is where it's split 🙈🙈
Is this what you need?
Carb flange?
Check it's right for your car as I'm not familiar with small block engines.
http://www.ebay.co.uk/itm/VW-POLO-MK2-GOLF-MK1-CARBURETTOR-FLANGE-MOUNT-052129765A-A1164-/222395476782?fits=Model%3AGolf&epid=534938118&hash=item33c7cdab2e:g:aD0AAOSwo4pYkZsb
Carb flange?
Totally forgot about this thread.
That's the same flange as I have on my 1.1 with a solex carb.
Thing is, I'm unfamiliar with webers and how they mount to the original flange? Is there an adapter plate of some kind on top of the flange, or do they mount the same as a solex?
Yes it is the flange I need I will get one ordered!! Cheers guys I'm having running problems with it so just going through stuff and trying to sort out 🙈🙈
