left hand side steering gaiter
(In Topic #207530)
be sure tyo mark the nut and rod position with tipex before you go ahead and remove the rod end then you can get it back to how it was before. they should only have adjusted the right side though, the left side is supposed to be fixed from factory. that and the fact it was 'very far out' suggests someone has been in there and messed it up or they are totally clueless
reference this to check your rack is close to factory:
also if the track rods have ever been off you may want to check the rack is centred as well
Smear a little copper grease on your wheel bolts, stops them sticking on the hub incase you get another tyre place with a buzz gun as that's what they all seem to use.
