Imput please
(In Topic #242761)
Maxspeedingrods carburetor
Hello people
Has anyone fitted the maXpeedingrods 4 Cylinder Carburetor 2 Barrel 38 dgs(I assume its a copy) to their golf I purchased one as I went from injection to carb I brought a new to me manifold brought new gaskets and a new base plate as the old one was too small (bells should have rang then) got it fitted turned the key and it idles a little jolty but runs drive it away on low revs it is like I have fuel blockage so I am assuits fuel mixture but need advice on how to set it up . Oh if I boot it it drives great it's just low speed pulling away and such please advise . (I have done the air leak check and its all good could the carb be too big I have a 1.8 . Thankyou ..
There are lag issues with the Forum, Please don't double post as it may take a while to post a response.
This response took about 2 minutes to post, whereas editing this line to add took about 2 seconds to post the update.
Do both barrels open at the same time, not progressive first one and then the other? if so i suspect its too big. from very distant memory the carb name you mention reminds me of the one fitted to the old 3 ltr ford capri.
Briano1234 sorry I didn't realise I had posted twice . My bad..
abfmk1 . Yes they both open at the same time it would be my typical luck if it is the wrong carb
I think you would do better with a twin progressive choke Weber, which would work fine at low revs and give power at high revs. An example would be a 28/36 DCD
