IGN timing on abf
(In Topic #210345)
I've thrown all ECU rubbish And fitted Peugeot 205 GTI dizzy with vacuum advance retarded
Just need set timing it's running 90â"…
Is these marks I need. I found them on web site says green mark to middle of hole
Sent from my KYOCERA-C6745 using Tapatalk
IGN timing on abf
Says red mark tdc
Green mark 6'
Sent from my iPad using Tapatalk
Green mark 6'
the red mark is the BTDC diamond you use for ignition timing. the TDC mark is a smaller punch mark. the big square thing is only for use with specialist VW timign equipment so ignore that.
What figure the diamond is on your flywheel depends on what car it came from, carb its 18 degree, injection its 6 degree
other thign to note is since its a pug dizzy the factory marks may not be any use at all anyway
If I set it up to diamond runs like bag hammers
If I move it forward to we're I've seen someone says to time up to runs lot better Just flat spot 3/4 k rpm
But takes off like rocket once passes point
The mixers all ok as just being set up plugs running nice brown colour.
As I says back to basic with Peugeot 205 dizzy
like i say 2 things to consider:
1. where is your diamond, 6 or 18 degrees?
2. does it even matter, as neither may be any use anyway with pug dizzy as its off a completely different engine
basically all you can do with these things is add advance and drive it, see how it goes. tweak fueling if need be, and back off if it starts to pink.
then take it to a pro for a full tuneup on a rolling road or preferably out on the road
