Hydraulic clutch, spec? Master cylinder and pipe size.
(In Topic #244585)
Hi,
I’m sure this has been covered before, but searched and couldn’t find anything specific. I’m definitely not the first or will be the last to install a hydraulic clutch, so need some advise from those with tried and tested setups.
What size master cylinder on pedal box? Research is showing most go for a 0.75 master cylinder? Is that correct?
To go with the master cylinder (assuming 0.75 master cylinder) what size pipe? Is 1/4” correct? I intend to use the standard vw mk2 golf slave cylinder at gearbox end.
is there any benefits in changing the mk2 golf slave cylinder (357721261A) to a mk4 golf version (1J0721261D)?
Thanks in advance.
Thanks in advance.
Last edit: by Carl Jones
