How to wire headlight warning buzzer
(In Topic #214849)
Did a search and could only find oil system buzzers… There's a surprise! LOL
So I'd like to fit a warning buzzer in case I leave my lights on as I am just fitting a new battery due to killing the old one through (you've guessed it), leaving my lights on.
I have tried to fit it - it's only 2 wires, how hard can it be?
Hard it seems!
I can either get it on when the car is running, on when the lights are on, or on when everything is off!
Big thanks to
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Flights-left-on-warning
I tried it and I have three 292 relays but narda.
It could be the way my fuse box is layed out.
It's an LHD and I'm certainly no sparky!
Give it a go and all the best.
Works on my 93 cabby, but not the Borther in Laws 93 cabby.
Doesn't work on a 90 Caddy either!
Strange innit?
If you scroll through a bit further there is a guid on how to wire on in using the wires on the back of the holder that the 292 relay comes with if you chop it off a later car
Ian
borednow said
This is a weird one!
Strange innit?
Ian
Yep it pee'd me off big time.
Mines a LHD drive 1990 Cabby and I can see the fuse box has not been messed with.
I bought my relays from Spain x2 and Italy x1 so maybe it's a language problem!
As an Australian mate of mine told me thirty years ago.
"It is not gravity that keeps us on this planet, the earth sucks!"
early type with bullet fuses or later type with blade fuses?
Edit….. I've just clicked on the link and all the info is in there so don't worry about my question…..
I'll get my coat and leave….
You can just connect the buzzer - 12v to side lights and the -ve to the door switch with a diode but it will work all the time, engine running or not.
So by wiring directly to the door and side, wire the relay normally closed (30&87a) in between the side lights and buzzer, wire the relay to ignition so when the relay is energised the circuit between the buzzer is open, switch ignition off relay will be closed buzzer will work when door open and lights on. The diode prevents it working from the passenger door.
I considered myself to be reasonably good at car electrics, but this one was making me doubt my abilities. Glad to see that it is not as simple as I believed it to be, but VW already have a 'maybe' fix! LOL
I'll follow the guide posted, get a 292 and see how I get on.
Thanks again.
Last edit: by huw169
Very strange but at least it makes a noise.
"a neeeee naaaaa neeeee naaaa sound"
Did it come from a Ford Escort MK2 Police 🚨 car by chance? 🤔 😂👍🏼
mark1gls said
Relay 292 works in my car but for some reason it makes a continuing neeeeeeeeee sound when my blower fan is in the 0 position and makes a neeeee naaaaa neeeee naaaa sound when the blower fan is in position 1,2 or 3 even though there is no keys in the ignition and every thing else is switched off????
Very strange but at least it makes a noise.![]()
Looks like you have a shared earth somewhere.
Clives does the same with the rear window heater. If that's on it makes the single tone.
Gotta love old cars!
But let's be honest if that is all I have to worry about then I can more than live with that and be thankful for it! 👍🏼
Sent from my Smartphone 📱
mark1gls said
I'll have to try the rear heated window switch and see what it does…![]()
You crack me up mate! 👍🏼
But you've got to give me a chance to get my own back by playing this year's GAP competition which starts at the end of the October ok 👌
You'll love it mate!👍🏼
I took the Instrument (console light) gray/blue wire and the parking light wires and cut them off the connector and soldered both of them to the heater switch power in wires.
When I leave my lights on, and turn off the ignition, all the lights on my car are off. There is no chance that I can leave my lights on. It is painless, and the only issue that I have is that the console lights are on during the daytime, which to me also means that my head light switch is on as well.
Head Light/ Marker lights off with Key out fix. | VW Vortex - Volkswagen Forum
Briano1234 said
Well while I have seen that 292 thing, after I had my fix, I decided that what I did was a tad different but better for my Challenged folks that occasionally drive my cars.
After I thought I'd finally finished behind the dash and actually screwed everything in nice and tight
Nice idea mate, I'm liking that
Ian
Should of asked you guys years ago! LOL
Many thanks!
1990 Golf GTI cabrio 1.8i. DX Engine
mark1gls said
Well they must be something funny going on with my LHD fusebox or I've got 3 dead ones, which I find hard to believe to be honest! 🤔
Oh well I will just have to be always mindful of checking.
Don't miss what you've never had, apparently! 😉 👍🏼
